Seat Upholstery Question
Allen B
Well-known member
Hi folks. I finished making the seat slings and formed the foam for all 6 seats in the model 5. Before sending them to the upholstery shop I wanted to ask about any issues I’m not aware of before doing so. Specifically, any fit issued with seats being too close to each other up front or the bench seats being too close to the walls. What size U to cut for seat belts to attach on the bench seats? To bolster or not? I’m leaving the final foam fitting to the shop. Any general recommendations? Here are the specs….
-Confor foam for all seat bottoms. I did 4” for pilot seats, 3” row 3 and 2” row 3. Variation of foam density’s.
-High Resilience foam for the backs. 2” all around.
-Superflight 101 for the seat slings with Stewart Systems. I covered them with EkoFill for UV afterwards.
-I first wrapped and glued the tubes with pre-shrunk 2” tape. Then attached the fabric to the tape.
Once covered it’s going to be impossible to alter without tremendous costs. Any advice would be greatly appreciated.
Thanks again,
Allen
You’ve probably already noticed that the clearance between the front of the sliding front seats and the cross tubing does not leave much room. My first seat cushion design wrapped the fabric around the front of the seat pan and it bound up trying to slide over the cross tube. So I switched to a different method of attaching the cushion to the frame. I have a bunch of 1000d ballistic nylon fabric leftover from previous jobs, so used that to wrap around and secure with Velcro.
Actually, no I haven’t noticed. I’ll need to take a closer look. You’re saying as you slid the seat forward the front fabric would bind? Thanks
Actually, it was the side of the fabric (some thick vinyl and a thin layer of foam headliner) that wrapped around the frame near the front of the seat frame. I had made a pocket for the front portion of the frame to slip into. There was enough fabric there that it was rubbing along the sides. So I eliminated the pocket and sewed a ballistic nylon flap onto the front edge of the cushion to wrap around the front tube. I used Velcro straps under the frame to wrap from front to back to secure the cushion to the frame. And some along the edges.
I’ll make note of that for the shop. Is there anything you would’ve done differently? Bolsters? No bolsters? Lumbar? Any design you may have changed in hind sight?
Here are pics of the 2 versions and the problem area. And yes, the pin is stuck in backwards. Just put the old cover on for the pic.
Very little clearance between the seat frame and the rails for the pin. The fabric would chafe and rub here.
Version 2 avoided fabric in this area.
I cannot comment on seat comfort yet as we are not flying. We are doing all the upholstery ourselves, so we might change something down the road, but for now this is where we are.
I see. Thank you for the pics. This is great info to have going into the shop. I’ll probably do a couple stage checks with them during the process to make sure it all fits.
One thing to consider which isn't mentioned often enough, is how the whole aircraft "feels" depending on the depth of foam you put into the seat pan - and it's not about how your butt feels!
If you make the seats too comfortable, then you might end up with a sore neck. Too much foam - too thick - pushes up the pilot's head position, meaning you cannot see under the wing without bending down.
With a modest seat foam thickness, you can see under the wings very easily clearly just by turning your head. This makes a huge difference, the whole aircraft feels large, open, and spacious. Naturally the height of the pilot's torso makes a difference here, so YMMV.
Too much foam can place your head too high, meaning you have your eyeline obstructed by the wing root or top of the window frame whenever you turn your head. This totally changes the vibe inside the cockpit, the aircraft feels more cramped - every time you want to turn the aircraft, check for traffic, or just see the view - you have to crook your neck. Plus it feels remarkably more claustrophobic. It's just not a great experience compared to a lower seating position.
I've flown in several aircraft fitting into each of the above camps, and it's a huge factor. It changes the entire feel of the plane.
Thanks. I did 2” in row 3. 3” in the middle row and 4” in the front. I’m 6’2” and sitting in the model 5 my head doesn’t come close to touching and it doesn’t feel cramped but I’m using firm and then fairly soft top foam so it probably compresses more than most. I’ll go ahead and put the seats back in and think this one through more because I don’t want visibility issues. Thanks again
