Thoughts on priming stringers.
PhilBC
I have stringers cleco’d in place on our BH5 build, so I can remove them to prime. I notice in some build videos & photos that they are often not primed. Just seeking input, particularly from earlier builders as to how they look after a few years and whether the surface deteriorates if not primed.
I have used self etching primer on some remotely mounted small items such as small trays, mounts, spacers etc., but if I prime stringers I would do them in a paint shop with a quality aircraft primer, as I expect the fabric chemicals could remove or damage a self etching spray bomb primer.
I am in a dry climate, but considerations include quality, resale, cost / time, weight etc., and am leaning toward doing them.
Thoughts?
Stringers are 6061 they will not corrode for a long time. The green primer in the wings is used mainly due to the 2024T3 construction which is a stronger alloy, but less corrosion resistant thus demanding the use of primer. We do not prime stringers on factory built aircraft.
My stringers are practically living in a coastal environment for the last 15 years, always hangered, but show zero corrosion. They are unpainted.
Thanks DBeaulieu, BH Aircraft and Battson for taking the time to respond.
Great advice ……gotta love it when the consensus from experienced BH’ers saves me both time and $$s 😃
