rodsmith
Well-known member
I know there is a maximum width for the wheel track that Bob specifies, but I can't find the reference. I believe it is measured between center of tread and 72" sort of rings a bell. With wings and engine mounted but missing a lot of empty weight mine is 69". Reason I am asking is because I need to adjust toe in. I am measuring 2 deg toe in both sides, wondering if I should try to spread the gear to 72" or Bob's max number and measure toe in again before adjusting it. I believe Bob states that alignment should be 0 to 1/2 deg toe out.
