3D Printing for Aircraft Parts
  • 3D Printing for Aircraft Parts
    Not really using 3D printed parts, rather using 3D printed parts to make parts...
    I have found that 3D printed parts can be a huge help when it comes to tooling and fixturing, to this end I will try to keep this thread up to date with parts that I find useful.
    First up we have the "Magic Washers"... these will be used to make the forms that make all the ribs, so indirectly a 3D printed part used to make nearly every other part! Kind of neat to think about.
    If you have access to a 3D printer and are interested in the files I am willing to share, I tried to upload here; but it appears that files with the extension .stl are restricted by the forum. Who would be a good point of contact to get this changed?
    Great idea, can you please try the upload now? I set a max size of 5mb but if that is too small let me know and we'll change it. By default, file extension types are all excluded. A few are allowed by exception, rather than the other way around. But we can always change it when there is a good reason to.
      I tried to load again, but my file is large, when generating STL files (especially ones with circular features) I increase the number of triangles, my file is just a little over 12MB.
      "Your file of 12.08 MB exceeds the limit of 4.77 MB."
        I wasn't sure how big to make the limit, it is now 15mb if you want to try again.
          Added at last, thank you for adjusting background settings.
            since Corona is keeping us home...i thought Id start learning CAD and make up some files..i downloaded Free Cad, what do you think of that program is it up to the task of making wing shapes and such.
            Any recommendations on good YouTube videos to watch to learn the art, I`m really only interested in making wing shapes with it. Not really doing 3d shapes or anything complicated.
            If anyone has recommendations or tips...Im all ears...
              Depends how deep you want to go. Unless you want to create some basic quick n dirty models, I would recommend Solidworks. It's the industry standard, highly compatible and well supported. And last time I checked for EAA folks, which most of us are, it's free.
                I used Solidworks for the aileron and nose rib forms and then 3D printed the forms.
                Scott Ahrens
                Bearhawk Patrol Plans Built
                #254
                  SolidWorks. As a EAA member, I downloaded it for free. Here is a great video that helps with getting started using SW.
                  https://www.youtube.com/watch?v=hVG5tMAhf3Q
                    Thanks for all the tips...
                    i was thinking of making up some 3d templates for rib formers and blanks.... donating them to Jared .... the Bearhawk could really use a builder assist package
                    help generate some revenue
                    he could sell it to registered plans holders.. the forms printed out ready to glue to wood
                    anything I make though ... Be a good idea you guys double check
                      Perhaps a good way to do this would be to have a Beartracks article about your journey. You'd be welcome to post any files here. We've updated the forum permissions to allow the .stl files here, and can also make other types available if you need.
                        I think 3D printing would be a great way to make molds for composite parts. Hoerner wingtip molds would be nice.
                          Solidworks is free with an EAA membership, but Fusion 360 is also free as long as you aren't using it for commercial purposes. I use Fusion because it has CAM capabilities for use with my CNC router.
                            Not 3D printing this time, but along the same lines... it could very well have been printed (the CNC was faster though at about 15 min to subtract material).
                            The story behind the part...
                            I tried making the cutout using traditional means... a jig saw with filing and sanding, a fly cutter with sanding, as well as careful router table free hand to sneak up on the line to sand. Needless to say none of these produced results that I was happy with, so I jumped into Fusion 360 and sketched up this part and then created the CAM and sent the Gcode to my CNC router, the part worked perfectly.
                            The part was positioned using the holed tabs traced, mostly cut out with holes followed by jig saw, then to the router table with a flush cut bit using the part as the template.
                            The template next to the blanks for ribs 1 thru 5:
                              3D printer file added/attached.
