Cap Strip Vertical spacers
  • Cap Strip Vertical spacers
    Guys, the plans call for the 1/8 X 1/2 vertical spacers on the spar are of 6061, any reason I cant use 2024?
    Please Advise...
    Project Plans #1299
    Ask Mark Goldberg for confirmation, but I'm pretty sure the factory only uses 2024 t-3 in the spar construction so that there is no confusion in materials. This was covered somewhere else on the forums here if you care to look around....
    Patrol Plans #156
    Working on wing ribs and spars
    West Chester, PA
      Al 2000 series and 6000 series are metallurgically different in several ways...... I would wait until Mark or Bob confirms IMHO.
      You can see some of the differences in properties graphically, for your interest, note the differences in specific strength - not such a big deal for spacers, but for cap strips you'd want to get it right: http://www.makeitfrom.com/compare-ma...61-T6-Aluminum
        The 6061 is plenty strong for this point and is cheaper, thus the call out. The additional strengths of the 2024 won't hurt at all here.
          I spoke about this withBob Barrows several years ago. He said that you can use 2024 instead of 6061 as it is stronger. However, you cannot use 6061 where the plans call for 2024.
          Eric Newton - Long Beach, MS
          http://bhtailwheels.com
            The problem I have found was that 2024 was only available in 12 foot where 6061 was available in 6meter lenghts. I coudn't find 6061 in South Africa so I bought a 4"X12" 2024 T3 sheet and cut the cap strips from that. I spoke to Bob about the doubler plates where I joined the cap strips on the rear spar and he was happy with my plan. Much stronger.
            all the best Gerhard Rieger
              Currently, having difficulty locating 2024-T3, 1/8 x 1 1/4 for the main spar cap strips. No luck with Aircraft Spruce, or Alro Metals Anyone know of a good supplier?
              Thanks,
              David
              The Airparts webpage only lists 6061-T6, guess I'll have to call.
              Thanks,
                Wicks T-4? The LSA plans specify T3/T4...
                Frank Forney
                Englewood CO
                EAA Chapter 301
