The plans call for 1/8 flush head ss rivets on trailing edge but the shortest 1/8 rivets i can find have a grip length starting at .062, it needs to be .050 or shorter,( any ideas) thanks wes
trailing edge
One method I have seen regarding TE installation was to put a tiny ball of thickened epoxy at the aft most inside folded corner of the TE where the aft end of the rib could just touch it.. The whole idea is to reinforce the TE/rib joint and to keep the TE from creeping forward because of fabric tension and wear and tear. This puts an unsightly wrinkle in the fabric just forward of the TE. Worked great on Pitts biplanes and they get the crap beat out of them. The balls must be small, remember they must be counterbalanced, filled with microballoons, or some other lightweight filler, and must contact the end of the rib to lock in its position spanwise. I plan to do mine like that.
Cheers
Gerry
Patrol #30
