Does anyone have a fairly accurate material list for fuselage tubing...i have found two so far ...they are close but a bit different here and there. for instance..one has 40 feet of 3/4 square .035 tubing and the other has 17 feet of 3/4 square .035 on the list...fair bit different. thanks gary
fuselage tubing material list
They are going to vary. I believe the T26 tubing you mention is only used in the doors - lots of variation there. I might not use any of that particular tubing in mine. Other variables would be float plane beef ups, differences in skylight / trim structures, motor mounts, suspensions, seating, etc..
