I'm probably over thinking this but I can't find a reference anywhere with an answer. I'm fitting the bent tube that is welded to the front vertical fin that the top stringers merge into. Recall that the front fin tube is welded 3/4" to left of center line of the fuselage. So is the curved tube welded to maintain the off-center plane defined by the front fin and tail tube (continuing with the divergence from the centerline), or do I rotate it to the right side and weld it to maintain the 3/4" offset parallel to the centerline?
Best,
John
Best,
John
