I'm building my spars and trying to make sure I have my capstrips the correct length. If I'm reading the plans correctly the drawing #3 is of the front of the spar. I'm getting a top front capstrip measurement of about 96.75 thst lays over the 142.125 inch capstrip. I have seen a few builders logs that cut theirs 118 inches. Can someone tell me if I'm missing something or what the correct number should be. I have plans 503 so they were before the wing load test. The recommendation from the test was to extend the top front capstrip back to the spar plate instead of a 72 inch capstrip. Thanks
Eli
Sent from my SCH-I545 using Tapatalk
Eli
