Matthew Schumacher and I are collaborating on a new electric trim mounted within the elevator/s. Comprised of a servo stepper motor and planetary gear motor. Acme thread/screw, using PTFE bushings and thrust washers. I'm doing the machine work and assembly design. Matthew is doing the electronics. The trim servo uses a programmable set point for one button take off trim, and infinitely adjustable. We
will be load testing and continuous cycling of the assembly until failure or sufficient time has elapsed W/O failure.
