Another piece of the puzzle to fit for this rookie builder.
I got Bob's O-540 installed to do some checks. My Vetterman exhaust is arriving tomorrow I think (Thanks Clint).
I installed a 1/4" plywood mockup firewall to do a couple of checks before I settle on the final dimensions of the firewall. You notice the white poster paper in the top corners. I shorted the radius about a 1/2". So making the plywood template saved a sheet of SS so far. I'd like to make sure I have enough clearance between the cowl and the exhaust. To do that I need to position the nosebowl, that I got from Bob, with the 1/4" -. 3/8" gap to the spinner backplate.
I'm installing a Vans fiberglass, 13" CS spinner on a 84" CS Hartzell. I thought this would be easy in that I incorrectly asssumed the spinner backplate would sit flush on the starter ring face. It appears that the spinner backplate is mounted to the prop and spaced out from the starter ring plate. I was wondering if there is someplace in a book or on the web that may have that spacing dimension. Or do I have to mount the prop with spinner to get it right? Thought I'd ask before I did all that work and there is a smarter, more better way.
Speaking of smarter, while assembling my landing gear struts I made the dumb mistake of adding a little extra ATF fluid while I was lubricating the O-rings and cylinder walls. The clearances are kinda tight so you have to push the piston, spring, brass cap assembly in with some force. So guess what happens when you get the assembly to slide in with your face right over the top of it with just a little too much ATF fluid in the bottom of the cylinder???? It gotta go somewhere and it comes out the piston tube like you wouldn't believe. Luckily I had my glasses on. So stupid I just laughed. Be smarter than me! That shouldn't be too hard. Skin on my face has seemed much smoother last few days
