Air Vents
  • Air Vents
    Air vents made from 2" 6061 tubing, flat sheet .050 5052 and 1.5" PVC drain pipe with caps. I spun the tubing on my drill with a drum sander mandrel and used a coarse file to take off approx .005". Used a 3/16 mill cutter and hand feed then in the drill press for the slots. Used a lathe to machine down the inside of the cap to fit over the 2" tube and the outside for weight. 3 sets here but one is already done. next firewall shutoff's.
    This gallery has 4 photos.
    Nice! At this point we only have NASA scoops in the lower Boot Cowl but we might want to add these too....
      Thanks for posting. I will have to give them a try.
      Patrol (modified)
