I forgot to install nutplates for attaching the fairings, does anyone have suggestions on how I can attach the fairings without nutplates?
Attaching Horizontal Stabilizer Fairings without nutplates
Different strokes... You might try this. I have been doing this for years, it works!. StingerYou do not have permission to view this gallery.
This gallery has 3 photos.
- Likes 3
Hari :
In Aircraft spruce---- (somewhere) they sell a steel gizmo that looks like an Adel clamp except its made for structurally mounting
things to the fuse. tubing. perhaps that could go on the tubing and under the cover. What you need is something like a 1/4 inch
bolt that is hollow and tapped #10 in the center. The outer 1/4 inch part would compress the clamp and the inner part holds the
SS #10 button head bolt which goes through the skin. maybe someone else could tell us if a special hollow bolt like that exists....
(or you could make them I guess......)
I think these clamps are in the same section as the steel tubing in spruce.
another way would be to put your nutplate on the inside of the cover but on the back of the opposite side. Use some kind of spacer that
would bring the nutplate up against the underside of the other face. maybe the spacer could be made from a piece of bent up .032 and that could
be used to straddle the cross tubes to help keep the sheet in position laterally.
I havnt gotten to that part yet - so those ideas might just be crap----- :-)
Tim
In the news letters Bob talks about attaching the door skins with machine screws after drilling/threading the 0.035" door tubes. You may be able to employ this method by drilling/threading the inboard 0.032 C-channel for #6 screws.
I like Stingers idea!Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
I have all ways hated any kind of sheet metal screw in an aircraft application. Seems like they all ways get loose over time. I know they
are used from several factory aircraft brands.....
Better for the roof on the carport I say ----- than my plane.....
My version of the barrel bolt is threaded on both inside and outside. Could quite tell if fastenels is threaded on outside.
If you dont need many--- you could just put some 1/4 inch stainless large area heads in the lathe and bore and tapp them for #10
on the inside .....
Tim
