looking at the plans there are joggles at the top and bottom of the centre rib at the front....but none I see on any of the other ribs that have spars worked into them...so it's only joggles at the front of main rib top/bottom...no joggle at the back of the main rib for the rear spar?....etc...
Joggles on the ribs
Would you make that joggle after the rib was finished or during the forming process..... ? and how would you do it since the bend line is about where the joggle is ?
Would I hand cut a depression in my form block at the front corner ?
Seems like a pair of forming blocks mounted in a big pair of vice grips might work ? Since the offset would be pressed through the bend radius--and that
zone is all ready work hardened--- what would the shape of the first 1+1/4 of the bend line look like with a radius AND an offset ? Doesn't seem like you
could do a jog without causing a too-tight bend radius there somewhere.....
Has anyone done it to show us what it looks like ? and share a picture ?Last edited by fairchild; 12-09-2018, 03:27 AM.
That tool looks sweet for flat joggles but maybe not for a curved or compound curved material. Since the joggle is only .032 you couldn't build it like that.
Might be able to take some 1/4 or 5/16 steel blocks and weld them together on one end (maybe with some stiffeners) and adjust the center offset to .032- or .040 .
The 2 plates might have to be bent to follow the curves of the material. or maybe even just ground. I will be trying that in the next couple of weeks-- so if I get something
that works easy I will post a pic of it.
Tim
