Nic asked for some pics of my rear window so I figured I start a thread to post the pictures in.
When preparing to build the rear window frames I decided I wanted bigger windows so my kids would have a better view. The whole point of my airplane is to fly with my family and I want them to enjoy it. What's the point of low and slow flying if you can't see outside.
I looked at pictures of Maules with observation windows and looked closely at the pics Jared posted of his windows and developed a plan of my own. I decided to follow the airframe structure because it was easy and athletically pleasing to me.
The top and aft portion of the window fit into steel "U" channel we formed and welded in place
The bottom of the window is held in place with screws/nuts that attach to an aluminum window sill. The sill is riveted to tabs that are welded to the fuselage.
AKschu had a great idea to use some appropriate size aluminum flat bar rather than nuts on the screws that attach the window to the sill. Drill and tap the flat bar and use it in place of the nuts. Great idea.
For the window on the right side I slightly modified the middle door support tubes. The perimeter door frame tubes are unchanged but the support tubes used to stiffen the frame I change a little.
I simply attached the window to the middle door skin with screws and nuts. I guess I don't have a good pic of that.
There is a significant weight penalty associated with big windows but I really like them and think they are worth every ounce.
