What are people using for hinge pins for flaps and ailerons. ANbolts and nylon lock nuts? Drilled AN bolts and castle nuts, or clevis pins (if available in.25inch. Cant seem to find on plans
Flap and aileron hinge pins
I am trying to figure out what to do at two hinges where the brackets to flaps are too close to center to get my an4 bolt slid in with a regular castle nut. I will order two clevis bolts and shear castle nuts for those two locations. I believe they will fit in the clearance. Last resort will be to drill a hole in side of nose rib for nolt head to slide in a bit, and use an4 with regular castle nut as i will for remaining 8 hinges. Always an option. Thanks for the quick responses for a dumb question.
Are you talking about the bolts that go through the rod end bearings? If so, you can use a regular AN bolt an nyloc nuts. Since the rod end bearings rotate, the bolt never rotates, so it's acceptable to use nylocs. I pointed this out to my DAR and he agreed.
- Likes 3
Exactly. This is how I did my RV-8.Originally posted by swpilot3 View PostAre you talking about the bolts that go through the rod end bearings? If so, you can use a regular AN bolt an nyloc nuts. Since the rod end bearings rotate, the bolt never rotates, so it's acceptable to use nylocs. I pointed this out to my DAR and he agreed.
Maule M5-235C C-GJFK (Sold)
RV-8 C-GURV (Sold)
No need to drill hole inside nose rib to install the bolt. it’s tight but there is enough room if using a proper bolt length. I’ve used castle nuts for all my controls, no clearance problem.Originally posted by Gary Wallace View PostI am trying to figure out what to do at two hinges where the brackets to flaps are too close to center to get my an4 bolt slid in with a regular castle nut. I will order two clevis bolts and shear castle nuts for those two locations. I believe they will fit in the clearance. Last resort will be to drill a hole in side of nose rib for nolt head to slide in a bit, and use an4 with regular castle nut as i will for remaining 8 hinges. Always an option. Thanks for the quick responses for a dumb question.
This is showing the aileron, as a reference.
