Interesting. I'll try some of the tough ones to see if can do it, but have plenty of help.
Aileron counter balance tube
Well this weekend I filled my counter balance tube, It was easier than I thought. I had a couple small sections of steel tube that fit nicely into my counter balance tube. I had a bucket of damp sand and poked the tubes into the sand to make a hole. to my dismay the sand collapsed into the hole. There went my idea. Never fear I had an idea. I wrapped a little masking tape around the tube, First layer sticky side out second layer sticky side in so I could slide it off the tube. I poked the tube into the sand then inserted the tape cylinder to keep it from collapsing. It worked I poured the molten lead into the form and it only singed the tape. I let it cool off and then had several lead plugs that slid inside my counter balance tube. Each plug was about 4-5 oz. I weighed my counterbalance tube then added the correct # of plugs to weigh about 5.5 lbs. each. Now I just need to put some epoxy into the tube to secure the plugs. There is a little bit of room left on each end of the tube to add some more weight if need be later. btw a coffee can and normal camp stove worked great. Be sure to wear gloves and eye protection.
This gallery has 3 photos.
I used a totally different approach. I used lead wool and hammered it into a solid mass inside the tube with a steel rod. No melting, no vapors, and the same end result. Don't hammer too hard or you'll make the tube swell!
In the end I figured it would have been easier to make the holes a little bit bigger and use a thick wall steel tube. I could get the same weight and there were no hazardous substances.
Lead wool is available from McMaster-Carr. Looks like steel wool but is lead.Russ Erb
Bearhawk #164 "Three Sigma" (flying), Rosamond CA
Bearhawk Reference CD
http://bhcd.erbman.org
Thanks for the tip Russ, I will look into that. I had also noticed that Rotometals had 5/8" lead rods 1' long that I was looking at epoxying in and expanding to size with a steel rod. I don't know if I could even buy shotshell shot for the price they are asking for the lead rods.Joe
Things still going well with aileron construction. Got one done and the other almost done. Counter balance still looking good.Last edited by markphillips1228; 12-12-2013, 09:46 PM.
