It will be a while before I get there--- but------
when you get to the point of starting to attach the wing skins---- I assume the rivet holes are all ready in the ribs------ how do you go about matching the holes in the skin to them ?????
I imagine you suck the top skin down tight around the LE using foam and ratchet straps so there is NO slack ----- but then what ? How do you transfer the holes in order to drill the pilot holes in the skin for the dimple tool ...... The skin would be 4 feet wide at that point --- hole finder wont reach----
Can anyone give me rough idea ?
Tim
Tim
