Hello everyone, I have a question about rivets on the .032 attach angles rib-to-spar. The plans indicate (5) 470 AD4 rivets for the spar surface of this connection, but do I use AD3's for the rib surface of this connection? (Noting the .025 right angle stiffeners along the ribs use AD3)
Spar attach angles
DWG 3B When this direction "TYP" is used "MS20470AD4 TYP" that means unless otherwise noted all rivets are AD4. So you use AD4 for all rib/spar or 0.032 angle/spar/rib connections. Rib 0.025 stiffener angles are AD3.Last edited by Sir Newton; 12-30-2021, 01:32 AM.
Not sure I agree because on the patrol drawing "Typ" appears multiple times.
"Typ" is used to communicate that nearby comparable features are to be interpreted the same as the call-out indicated on drawing. So Typ does not mean all rivets lacking a call-out, only those included in that specific set of features e.g. angle to spar hole pattern.
The fastener from attach angle to rib could be stated more clearly, I agree.Mark
I am referring to mobel B wings. "DWG 3B" for BH5. Not asking clarification on the model was a oversight on my part.Last edited by Sir Newton; 01-01-2022, 01:10 AM.
