flap pushrod bearing
  • flap pushrod bearing
    Hello, wondering what everyone is using for the flap pushrod bearing. Is it a piece of 1/4"x.028 4130 tubing installed with oil/grease/anti-seize knowing that it will need re-lubed every annual or something like an oillite bronze? Thanks.
    Joe
    Aircraft Spruce part# 03-17300 1/4x3/16 .032" wall brass seamless tubing is what I'm thinking. $4.90/ft
    Mark J
    • bestbearhawk1231
      bestbearhawk1231 commented
      Hi Mark, I remember seeing that in the catalog. After posting, I had found some oillite bronze sleeve bearings at Mcmaster-carr PNs 9368t98, 9368t101, 9368t102. A few strokes of a file would bring the total height down to what is called out in the prints, if that would even be necessary on assembly. Price is about what a foot of brass tubing would be. My big concern with the brass tubing is how long it would last when compared to bronze and how big of a PITA it will be to service in the future.
    • jaredyates
      jaredyates commented
      Joe, I'd put that question to Bob also while you are on the phone with him. And let us know what he tells you!
    Joe, your oillite bronze idea is better than mine.
    Sure is great that we have this forum to share ideas!
    Mark J
      I purchase my wing steel parts from Avipro. They used a steel tube as the bearing. I have seen the same used in similar applications in Pipers and Cessnas for parts that do not move that much. I always lubricate every annual and have never had a problem. I would also think the oillite bronze would be good ok.
        Hi guys, an update. I called Bob earlier today while I was at the shop and he said that steel tubing is plenty good for the application. He said that both of his 4 places (not sure about the others) had a piece of steel tubing installed with regular grease and has never had a problem. He also stated that a harder bronze would also work well for the application. Since I am pretty sure I have the tubing laying around that is what will be going in.
        Joe
