Bearhawkers
I am getting close to running the aileron cables. I am looking for some advice on how much cable I should cut for each section.
1. the cable from the bellcrank around the pulleys and down through the strut and into the fuselage to connect at the sticks.. Approximate length?
2. the rear cable that runs through the fair leads and connects in the upper fuselage.. Approximate length?
Thanks Yadama
Thanks Yadama
