1. Gascolator under floor, or hung on firewall? If hung on the firewall, this would require a belly drain I guess between the selector and the gascolator since it's uphill?
2. Is everyone welding the tabs onto the longeron ahead of the forward door post/former? Or just letting the tee be supported by its incoming fuel lines?
3. Looking for examples of stubbed off fuel line at wing root area on fuselage. I read that hose is discouraged, but it seems like a good choice for a joint/connection to the wing fuel lines.
Any other tips? I see a lot of builders relocating their fuel valve/selectors to the left side of the flap lever.
Thanks.
Thanks.
