Sealing Fuel Tank Filler Necks
  • Sealing Fuel Tank Filler Necks
    I'm wondering what others have done to seal where the fuel tank filler necks protrude through wing skin, if anything. I had originally thought I would use a small bead of ProSeal, but wondered if there is too much movement up and down that would quickly break the seal. Also, any thoughts on how much clearance to leave around the filler neck? Mine fit fairly snug - not tight but snug. Thanks.
    Larry Driver
    Google is your friend
    Hey guys, I’m getting ready to cut the hole on the skin for the filler tube and don’t want to mess it up. Since the top skin is already riveted I’m
      Some folks have used a rubber toilet gasket. I used a product called lexel, but it has not been especially resistant to fuel.
        Thanks, guys. I have already made rings I was going to rivet or fasten with screws and nutplates to the top of the skins. I wasn't lucky (or that skilled) with the placement of my original holes. Like the idea of the neoprene sandwiched in between using screws to attach so it can be replaced if ever necessary. Have heard good stuff about Lexel for sealing around plexi, etc. but can imagine it might not be "fuel friendly."
        Larry Driver
