As I see it, what is important is the angle that structure CS tilts back at the top. The main gear loads that transfer up from the axle through the shock should continue in a straight line up through structure CS. I am working on a Patrol so can not give you a number for a 4 place. Ed
Mark, Where do these dimensions and drawings come from?
Wee is correct. The tubing is cut and coped to +/- 0.010â€. After final welding my fuselage was within 1/32†tail post to the upper outboard motor mount bushings....I built a jig...tubing snapped into place. Was VR3’s first kit...the only mistake were the two vertical tubes front doors..which was correct on all future tubing kits.
