As I ponder the plan for my fuel system a couple of questions have come up that I haven’t found to be “googleable.†I am planning on using the EFII system which has two return lines through the selector to the tanks. It seems like the fuel lines from the tanks to the boost pump need to be larger to accommodate the total fuel flow, but I don’t see any recommendations for line size. Did anybody else use 3/8†with good results? Also, I assume the return lines would be fine at 1/4â€...
My second concern is the fuel selector choice - it seems the Andair valves don’t have a “both†option and the SPRL only come in 1/4†connections. What solutions have you all found here?
As always thank you for any input and ideas!
Ken
Edit: For anybody who is curious: Mr. Paisley at FlyEFII has explained to me that a BOTH setting does not necessarily direct the fuel evenly back to the tanks and could result in an imbalance which is why he recommends the Andair L-R-OFF valve (which sports the AN-6 aka 3/8†fittings). A BOTH valve could be used with a header tank for the return line. As I don’t want to get into that large of a fuel system modification, and don’t like not having the “BOTH†option it seems I have more decisions to make...
Ken
