Hi Guys,
so I went out this evening to drill off my aft tip rib and aft root section - the previous owner had drilled them off and then removed them for storage, so I thought it would be just a case of chucking in some rivets and on to wingtips :-)
1) My template doesn't hug the form of the upper wing. Sometimes there's up to 1/4" gap between the skin/ribs and the wood. Is this a problem? I've looked, but the back of the template seems straight, it hasn't warped.
2) When I use the template, I push it hard up against the nose, and then pull it down to match the ribs as best I can, and hold it with clamps. Or should I let it sit at its natural resting position?
3) When I temp-fit the tip rib / root rib, the trailing edges are a good inch short of the cut out in the template. I haven't hung the ailerons/flaps yet to see where they end.
Should I be worried? Or do I just drill everything off, and match up the trailing edges later?
In another part of the QB manual, it says to wait until you hang the ailerons.
Eric Newton's manual says to match the aileron trailing edge to the tips you've already installed. Which comes first?
Can anyone walk me through it?
Am I missing something really obvious?
Thanks,
James
Thanks,
James
