Hi all,
I'm puzzled about locating the screws/nut plates for the aux tank covers on my A-model wings. The build instructions say to position them "...so they fall midway between the existing skin rivets (to give room for nut plates, etc.)," It seems if I do this I won't have screws at the corners of the covers - the first screw on each edge would be about 1-1/8" in from the edge of the cover:
And, the rearmost "between the rivets" location on the long edges of the cover is directly in line with the rear spar, so it doesn't seem possible to put a screw there - which would place the rearmost screw on each edge roughly 2-1/2" forward of the aft edge of the cover screw locations.
The "replace all the rivets with screws and nut plates" approach seems like it would end up matching the design of the main tank cover's interface to the wing, but also seems like a lot of work for questionable benefit.
Here's a couple more pictures of the rear edge of the opening:
Any input would be welcome!
