Bh5 ap
  • Bh5 ap
    I have the rear auto pilot mount from Bearhawk but I am using Dynon servo's and the pitch server doesn't fit. I knew this going in to it. I came up with a point to mount the pitch servo that seems to have no issues but I would like other opinions. This mount is a quick mockup. I would make it out of thicker metal. The last two pictures show the servo at each full deflection of the elevator. The big white bar is just some junk laying round the show that would work quick to connect the servo and elevator bell crank. Does anyone see anything I am missing?
    Thanks
    Travis
    Travis M
    Kentucky
    Received December 2022
    Builders Log
    I would use the factory mounting plate as well. that plate needs to be extremely stiff. they use 1/8" plate. your dynon servo will work just fine i do it all the time.
    • FFTravism
      FFTravism commented
      The servo will not fit on the factory plate. If I use the spot in the pictures the plate will be made in 1/8 plate also with bends for reinforcement.
    What's the distance from servo arm to elevator? Wondering about possible flex in the push/pull tube connecting the servo to elevator....
    Disclaimer: I am only familiar with the Patrol but that looks okay to me.
    Good luck with your build!
    Dave
    • FFTravism
      FFTravism commented
      The rod at the official mounting plate is about 24 inches. This would be closer to 20-21inches.
    For those wanting to use the Factory Pitch/Yaw bracket with Dynon, the Dynon servo will work using 7/8" aluminum spacers, that Mcmaster Carr stocks. Add these between the servo bracket and the mounting plate.
    pb
      This is how I mounted Johan’s early mod 5. 3/4” angle under stringer on working side. Plate is .063 2024-T3. A small plastic fairlead was needed for the close elevator cable which is friction free.
        Here’s how I mounted my dynon pitch and yaw servos
        • FFTravism
          FFTravism commented
          That was my first idea to just mount on the other side of the plate. Was that length of rod ok? I was thinking might have to increase the size. Do you have plans for access after the plane is fabric covered for maintenance?
          Travis
