Hi Everyone!
This is my first post here as I am a new Bearhawk owner. I recently purchased a beautifully built 4 place from a local builder who did a fantastic job building a beautiful airplane. I am currently in the process of getting some tailwheel training as my previous 4000 hrs have all been in nosedraggers ranging from C172s & Twin Otters to Learjets.
Before I get to my questions here are a few tidbits about the aircraft to better help get answers
- 4 Place Bearhawk
- Lycoming IO-360 200hp Engine
- Dual MGL Odyssey Gen 2 Efis
- Empty weight 1560lbs
- Goodyear 26" Tundra Tires and an Alaska tailwheel.
- Most of the flying so far has been done close to sea level 3000ft and below.
Questions:
1. The airspeed indication on the MGL efis units seems to be a bit off. I have run them through calibration with a Pitot Static test kit from the local AME and they check out ok on the ground with a few calibration tweaks but in the air they seem to have quite an error. In cruise I am struggling to get anything more than 90kts indicated. It seems to be consistently under reading in the "high speed" level flight regime and slightly over reading in the "slow flight" regime. The pitot and static ports are located on a long pitot tube on the left wing. Any ideas?
Is 90kts reasonable for this aircraft with the big tires? From experience it feels like I am moving faster. Ie. On downwind with 24" and 2400rpm I am indicating 75ish kts but experience and the seat of my pants tells me I am going much faster. The approach speed with flaps 25 seems to be around 55kts is this correct?
2. Tire pressure: What is the optimum tire pressure for these wheels? For the time being I am operating mostly on pavement until I get comfortable with the aircraft.
Thanks in advance for your answers it looks like you have a great community here.
Baloo
- 4 Place Bearhawk
Questions:
Baloo
