I was reading through my plans and didn't see much detail on the horizontal stabilizer strut for the LSA. Someone asked about it a couple years back in the LSA forum, but it didn't seem like they found a clear answer. ( http://bearhawkforums.com/forum/bear...abilizer-strut )
I have both the Patrol and LSA plans. As mentioned in the older thread, there is a drawing of the strut on page 21 of the Patrol plans, with no material/details called out for the sheet that forms the attach points. "Horz. Stab Strut 1.012 x .428 x .035" is called out next to the attach point detail on page 19 of the LSA plans. It looks like both the Patrol and LSA use the same strut tubing.
Looking through Eric's builders manual, he shows the process for building a stab strut for the 4 place. (After the stab incidence is set) It looks like 035 formed into a channel, notched into the strut for the bottom attach point, and the strut flattened, bent and drilled to match the horizontal stab (top)attach point. This seams reasonable for the LSA and Patrol as well? Does anyone have additional information?
I also note that the LSA plans show a 3/4" long front stabilizer attach bushing that can be adjusted "as needed for stab. trim" (pg 17). It looks like the plans call out -2 deg angle of the horizontal stab. I'm assuming that after the horizontal stab is mounted to the rear attach point, it is set to -2 deg, and the attach bushing is fine tuned to hold the stabilizer at that angle. Does the horizontal stab incidence ever require fine tuning after the aircraft is flying?
