Just looked at the plans for both the 4-place and Patrol, and they both look to be threaded so the fittings go all the way through both tubes. Interesting.
Looking at the way Eric Newton did his, although it's hard to see from the photos, he welded a nut to the hinge to capture the grease fitting, and drilled a very small hole through the tubing to allow the grease to goosh through. If I recall, the fitting never went through the outer tube, only up to the surface, and the nut held the fitting in place.
Snaps from his builder manual:
