Hi everyone,
I wanted to share some more information about the Surefly "SIM" mags. I am looking at installing this product, and found the internet left me wanting more information. Their website has a lot of detailed information and it takes time to dig deep enough - but there are a few natural questions which were left unanswered, even after consulting other forums.
I won't post everything about them here, just stuff I couldn't find without calling their staff. Hopefully this helps anyone looking to install this product.
So that's what I've learnt so far, in addition to their extensive documentation.
I know this won't benefit many on this forum, but it's good to have a Google searchable resource online either way.
- Their wiring diagram shows the first ignition powered directly by the ship's battery. This means there's no way of switching it off completely. I am told the current draw by the SIM when shutdown is just a few milliamps. This mean the ignition would flatten the main battery after about half a year or so, if the plane wasn't flown.
- Some people have been saying that electronic ignition causes excessive interference (RFI), including the SIM. The testing conducted by Surefly team demonstrates that no additional noise is created by their install, no additional shielding is required.
- They talk about their system operating better with a larger spark plug gap, 0.034 for instance. The typical gap is 0.018. They said that a smaller gap leads to a longer dwell, lower voltage, cooler spark. The larger gap delays the spark very slightly while the voltage builds, and the spark is higher voltage (proportional to gap size), hotter, and shorter dwell. The same volume of energy is delivered in about half the time. Their testing has found that engines run slightly smoother with the shorter, hotter spark. They recommend allowing the plugs to burn out the gap from 0.018 to 0.034 naturally over a couple of hundred hours, rather than opening out the plugs by hand.
- Their system sets the advance to 0 degrees BTDC below 400 RPM, for starting. There is also a timeout feature, so if the engine is cranking really slowly the spark can fire before reaching TDC causing a weak kickback. They also increase the spark dwell and spark energy to 50mJ, which is about 50% more energy than normal. They tested this higher energy spark in the normal operating range, and there were no obvious benefits over the normal 35mJ spark. It's only beneficial for starting.
- I am installing two 6 cylinder engine SIM mag units, which means a small backup battery is required. Per their wiring diagram, this backup battery is basically charged by the master bus in normal operation. Throwing a DPDT switch isolates the second SIM mag and the battery from the rest of the aircraft's electrical system. This allows one SIM to continue running while drawing down that battery, in case everything else fails. With a 75% voltage factor of safety, that allows for over 3 hours flying in the event the ship's battery fails totally and the alternator fails too.
- All EI systems seem to claim a fuel savings benefit. For instance, Pmag claims about 10% savings. Surefly shoots straight on this one, saying fuel savings are totally at the pilot's discretion. Installing their EI system (or any other EI) will not save you fuel unless you set the red knob differently. It is certainly possible to save up to 8 to 10% fuel burn, but you have to run the engine a lot leaner, certainly lean of peak. Of course, running leaner with EI will not cost much power or airspeed. The engine is developing more power relative to given RPM / MAP setting, below 25 inHg MAP or below 75% power. This is because of the increased advance and hotter spark. This increased power also results in the engine CHTs running hotter when lean, about 20*F.
- Because their system returns to 25 or 20 degrees BTDC (depending on your engine model) when the MAP gets above 25 inHg, those running extreme oversquare power settings many need to reconsider how the operate their engine to see any cruise flight benefits from this system.
- Their system is not designed to run on pure autogas alone, such as 94. They have done testing with autogas, and at full power there is very little margin over detonation. Although that being said, at full power their system has the same timing advance as normal mags. That is food for thought... Their testing also revealed that, when running 100LL / AVGAS, below 75% power there is almost no way to induce detonation.
- The EI system shines the most at higher altitudes. Above 6,000ft where normally aspirated engines suffer from the lack of ambient air pressure. As the MAP drops off and the amount of available Oxygen reduces, the hotter spark and greater timing advance pays dividends by delivering more engine power relative to normal magnetos. This is where pilots will see the greatest benefit from EI in terms of material changes to their aircraft's performance and fuel efficiency, cruising at high altitude.
