I'm ordering my covering and painting materials for my 4-place. I'm using SuperFlite System 7. I got a quote from Molly Dean with quantities for a Bearhawk based on her estimations. Does anyone have a complete materials list of an actual covering and painting of a Bearhawk using SuperFlite? Specifically I would like to know the quantities of primer and paint. I just want to try to get close on the coverage, especially the color quantity so it will come from the same batch.
SuperFlite System 7 Materials List
I've thought about this, since reading the initial post. I did Superflite, through the primer, on my Patrol. I can't imagine a half gallon difference between the Patrol and 4 place. My reluctance to respond is two fold; I used an automotive paint (Nason ) for epoxy on the metal parts and the top coat. Second, the primer on the fabric is going to depend on your personal taste. The Superflite fabric primer is a very nice high build primer. It sprays well and dries quick. I think the manual says that 2 coats are acceptable before top coat. I'd shoot 2 medium coats, let it dry, wet sand most of it off and repeat. I probably sprayed 6 coats and sanded off 3 or 4 of those coats. That left a real slick surface for the top coats. I bought 3 gallons of the fabric primer. It could be done with 2.
I dont know mixing ratios for the Superflite top colors, so I cant comment.
The Superflite system is all solvent based, so the smell is strong. I don't find the smell any better or worse than Stits. I like Superflite waaaay better! The fabric primer is a joy to work with! It's also great on fiberglass parts.
Hope this helps a bit.
Mark, the paint job you did on your Pacer is amazing. I wish I could do half as good. I have to say though, the areas we got lucky with on our paint job look fantastic and are very shiny. It's too bad we couldn't get the whole plane to look like a mirror.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Mark, No but I haven't asked. When we were having issues we were told that if sprayed correctly there is no need to dont anything afterwards. They are right. Also, in cool weather the paint flows for days. The paint looks so much better a couple days later. The side we screwed up bad we sanded with 320 and resprayed, it looks awesome. But after a few days the paint gets really tough, is bet it would color sand pretty well. I plan to try it on the side we didn't respray but it will be a while before we attempt it.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Originally posted by wheeMark, No but I haven't asked. When we were having issues we were told that if sprayed correctly there is no need to dont anything afterwards. They are right. Also, in cool weather the paint flows for days. The paint looks so much better a couple days later. The side we screwed up bad we sanded with 320 and resprayed, it looks awesome. But after a few days the paint gets really tough, is bet it would color sand pretty well. I plan to try it on the side we didn't respray but it will be a while before we attempt it.
