Something I've been mulling over a bit now. If you can count on both tanks for max flow at takeoff attitude with minimum fuel, does it make sense to combine them at the fuel valve into a 1/2" line? By my numbers it seems that one 1/2" line can be nearly equaled by two 3/8" lines (1.988). I'm considering doing this at the fuel valve since it seems a waste of capacity to not.
My goal is to provide enough flow to a fuel injected engine so as to not require a fuel pump, if that's possible. Thoughts?
Tens of thousands of planes flying with a system which works reliably and is easy to maintain are a safe bet to copy.
