Where are people getting the 10-32 socket head bolts for the strap tensioners? Aircraft Spruce and Wicks sell them, but only 3/4" in length. That doesn't leave much room for adjustment, after they go through the tensioner bars. What are you using, and where did you get them?
Bolts for tensioners on fuel tank straps
I got mine at Ace Hardware.
Yesterday I installed my tanks while the wings are temporarily attached to finish fuel connections and check for leaks and aux pump operation. Even using longer "starter screws" as Mark G suggested for the tank straps, I found it really frustrating to get the screws started. Good that it's winter and the hangar door was down to spare my neighbors a few choice words. Ended going to my local Ace and bought a 6-inch long 10-32 threaded rod. What was a difficult process became very easy. Lines the two straps up nicely and you can push the bottom strap up the rod to bring the two together and insert the second correct length screw, then remove the rod to insert the other screw. Highly recommend.Larry Driver
I've looked at Eric Newton's pictures of his build, and it doesn't look like there is any locking mechanism on these bolts. Is that correct?
Hanger straps hold the tanks, while allowing for (relatively) easy removal. The hanger straps are lined with thin rubber insulation, to avoid abrasion. When the straps are tightened, I could detect absolutely no movement of the tanks in the wings. Believe me, they're very secure.
