Hi everybody, Those who are already past this stage, can you tell me what the lenght of the #6 stainless screws was that you used for your cover plates?
Fuel tank covers and inspection covers screw lenght
Interesting comments…my experience has been somewhat different (perhaps not the most popular it seems…lol) though. I have used stainless screws in all the inspection plates/access covers in all three of my Bearhawk projects. The covers have been off/ on MANY times and I have never had any problems with galling/seizing. In searching the RV builders archives I find that many others have had the same experience with no issues.
If you do use stainless screws, here are a couple of things to consider: I always use “Easy Turn†lube on the screws (like you use on all the aluminum AN fuel fittings…) I have heard that some like to use the wax from a toilet gasket, but have never tried this myself. Use a toothpick and put a small drop in each nutplate. Also I NEVER use power equipment to install/remove the screws…carefully hand drive them. Less heat buildup that way. Some have even recommended running a tap partially through the nutplate to remove some of the friction due to the locking/clamping feature. I have found this to be helpful on the monadock clip nuts I use on the floorboards…they seem to have a LOT of friction no matter what kind of screws you use! Just my thoughts…here is a link with some points to consider…
Collin
Working on the last few things before I close the wings. I noticed the tank bay holes drill at the factory are not dimpled like the rest of the bottom wing skin. Nor are the skins. Obviously they still can be but is the intention to use non-flathead screws?
Unless the model B is different than the original, I'd countersink the wing skins, dimple the cover, and use 3/8" or 5/16" screws. That's not any official answer, just the way it is done on mine.Originally posted by svyolo View PostWorking on the last few things before I close the wings. I noticed the tank bay holes drill at the factory are not dimpled like the rest of the bottom wing skin. Nor are the skins. Obviously they still can be but is the intention to use non-flathead screws?
with the success you've had, do you think it might be careful torquing. is there an inch pound rating for these.Originally posted by Collin Campbell View PostInteresting comments…my experience has been somewhat different (perhaps not the most popular it seems…lol) though. I have used stainless screws in all the inspection plates/access covers in all three of my Bearhawk projects. The covers have been off/ on MANY times and I have never had any problems with galling/seizing. In searching the RV builders archives I find that many others have had the same experience with no issues.
Collin
I see a difference in application. I install them by hand. I have never lost one during installation. I use a power screwdriver for removal. It makes sense that it would generate more heat with the power screwdriver and I lose them during removal. I still can’t pick them up with a magnet when they fall where I don’t want them. They do look good.
I have used a large amount of SS and nylocs on boats. The smaller the better, or maybe a better description is the bigger the worse. 1/2" or bigger, a couple turns and then stop and let it cool. I considered them 1 time use, and if you had to remove them, replace them. Half the time you had to remove them with a grinder and cutoff wheel.
6-32 or 8-32 isn't as bad. I think the screws that will rarely be removed will be SS. The ones that will be removed routinely will be CAD plated. I wish I could find some 100 degree hex or star drive flat head screws but so far no luck.
I was also a maintenance officer in the USMC. Side job to being a pilot. The plane I flew was held together with hundreds of flush (hex drive if I remember) screws. No power tools allowed, or on site. They used hand augers only. I don't know what the fasteners were made of. They could swap a motor in 20 minutes, and I think 15 of those were external fasteners.
SS and friction lock are a bad combo, but 6-32, occasionally used is OK I guess.
