Ive read that a wing strut jig is a must when installing your wings. Can anyone tell me how they made it or does anyone have one to lend or buy?
Wing strut jig?
Well, i talked to mark last week. He was very helpful but also very clear that he doesn't have the time to be as helpful to this that may have bought the kit second hand. I understand that and that's why i would rather rely on the community.
Are you asking about the drilling jig for the spar to fuselage attach bolts?
Screen Shot 2018-02-18 at 7.15.10 AM.pngBrooks Cone
We took a different approach on our 4 place. We built the wings with the 3/8 offset using undersized holes. A threaded rod was run through the fuselage attach points with all the holes undersized to locate and weld the fuselage attachments. Nuts were used to hold the attach points exactly where they needed to be. The rear attach was built slightly wider between the ears so we could shim the rear to snug vs worrying if it will come together. We did a trial fit and to verify that the attach points were good. The wing attach holes were smaller than the fuselage attach points that also had undersized holes. We set the wing in the fuselage attach points and clamped the attach points so nothing can move. The aluminum holes were smaller than the steel holes so very little visual judgement required.We drilled the attach holes out in steps and as soon as the bit hits the steel on the other side it auto aligns. Drilled it close to size in a couple steps and reamed both points to a tight fit the bolt. The actual angle is 1.35 degrees or 3/8" over a 32" circumference x 360. It really is hair splitting and getting the jig alignment exactly to within a degree may be hard. The attach points are a triangle that are hard bolted so the clamping forces would resist rotation that it is not a hinge arrangement.
I get that it is supposed to be a hinge but is really not as there is no loose fit of hinged connections. The simplest solution would be if the design attach points were adjusted 0.188" up and down to align with one another. A design change that aligned the attach holes would simplify a lot of lives and aligned holes would likely not affect much of consequence.Last edited by Glenn Patterson; 02-18-2018, 10:28 AM.
Originally posted by Bcone1381 View PostAre you asking about the drilling jig for the spar to fuselage attach bolts?
