Header tank design and location
    commented on 's reply
    Regarding your question "why venting"... Have you seen the post by Whee, literally two posts above?
    Because venting tanks together keeps you alive
    "Airspaces of tanks with interconnected outlets must be interconnected"
    Cessna always vented theirs, and there are a bunch of commercially available "surge tanks" which are used to convert carbed cars/boats to EFI. That is what I am using. 100% of them have vents.
  • kestrel
    replied
    Originally posted by Seth Kroenke View Post
    1. Will I be pressurizing my fuel system by returning 20PSI fuel (assumption of the pressure of the return line) to a gravity system in a small header tank. Is this even an issue?
    There will be a pressure regulator that drops the pressure to near zero before it is returned.
    2. Do I really need to worry about the temperature of the fuel being returned? I feel like no, because the fuel never hits the hot part of the motor (front of baffling), but I am second guessing this slightly.
    I can't be certain for the Conti system, but I've heard that on some FI systems a lot of the heat comes from the fuel pumps pressuring the fuel? If this is the case, you will need to worry about heat. EFII asks for a minimum of 5 gallons in the header to support cooling.
    3. Do I need to vent this header tank? Or will the fact that the main tanks are adequately vented suffice? I would rather not have to weld another bung into the header tank and then plumb back up to the wing tanks.
    Yes! It must be vented! The header tank can't fill if the air can't get out.
    Leave a comment:
  • Seth Kroenke
    svylo, why does the header tank need to be vented? Wouldn't the vents from the main tanks supply the appropriate venting to the entire system?
  • Seth Kroenke
    Kevin D,
    Are you able to take a call from me regarding your information on this post? It appears you have the information that I am after as I complete my system. I'd love to ask you a few questions. As a side note, I wrote a post last night to the general group regarding my 3 remaining issues. Your advice is incredibly appreciated.
    I am not flying yet, about to do FF testing and weighing the thing.
    I originally thought return fuel should be plumbed into the top of the tank. Turns out it is preferable to return it low in the tank, away from in fitting feeding the pumps. This keeps bubbles and foaming down.
    1. It shouldn't pressurize the tank if everything is done correctly, which includes venting the header to the main(s).
    2. I can't answer that for MFI. If there is significant heating of the fuel, this could be a problem. Cessna 180 series used TCM MFI, and as they used header tanks to return fuel to. One of the solutions to this is a large header tank. I have zero experience with these Cessna's, so I don't know how big their header tanks are. Short answer - I don't know for your system.
    3. Yeah the header needs to be vented. I vented mine to one main tank. I will hopefully change this at some point to both tanks, which will then be vented together.
    Hope this helps, but keep in mind, Mine is not successful yet!!!
  • Seth Kroenke
    replied
    I have been impressed with your answers on the forum describing the FI systems in the Bearhawks. so much so, that I decided to join (unlike me) and reach out with a few questions.
    I am in Alaska and am in the final stages of completing my fuel injection system. I have a question regarding the header tank and specifically the return line plumbed to the header tank.
    I have the factory IO-470 MFI system starting with 1/2 fuel lines feeding a fuel selector of L,R & both, then flowing to a 1L header hank (a small tank!) that we welded out of 1/8" aluminum (pretty heavy duty) and located on the cabin side of the firewall. From there we flow into a "Steve's gasgelator" and then to the CJ electric fuel boost pump and finally to the engine driven fuel pump (that is on the back of the motor and has scatt tube providing cooling. I have the Atlee vented fuel caps (It is a high wing aircraft).
    My question is the fuel return line. Right now I am planning returning the fuel to the top of the header tank. My concerns are 3 fold:
    Any input would be greatly appreciated!​
    Leave a comment:
    replied
    I saw them several months ago and made a couple of inquiries. I really liked their "mini-header tank", as it was what I was wanting to make myself. It is very expensive, as are replacement pumps. It is also internally regulated, but not with a reference to MAP, which is what SDS said they prefer. It also has plastic fittings. It is very slick, and I really like it at first.
    Walbro pumps are 1/6 the price. I would probably replace one every 5 years/1000 hours as a maintenance item.
    Leave a comment:
  • way_up_north
    replied
    Hi guys, I`m no where near thinking about fuel systems and such..I`m not sure if the following is applicable to this... ive been watching some of the Viking Engine(auto conversion) videos....They have 4 or 5 videos about header tank placement and they sell tanks and pumps....Their engine is fuel injected so I thought it might be worth a mention.....I was thinking maybe their tanks could be used with your application and save you some money over general aviation offerings..
    Leave a comment:
  • whee
    replied
    I've beat this drum before and I probably will again. Something about experiencing multiple fuel starvation engine failures due to a design flaw tends to leave a lasting impression.
    Sorry for the slight, but relevant, tangent svyolo.
    23.975 Fuel tank vents and carburetor vapor vents.
    (a) Each fuel tank must be vented from the top part of the expansion space. In addition -
    (1) Each vent outlet must be located and constructed in a manner that minimizes the possibility of its being obstructed by ice or other foreign matter;
    (2) Each vent must be constructed to prevent siphoning of fuel during normal operation;
    (3) The venting capacity must allow the rapid relief of excessive differences of pressure between the interior and exterior of the tank;
    (4) Airspaces of tanks with interconnected outlets must be interconnected;
    (5) There may be no point in any vent line where moisture can accumulate with the airplane in either the ground or level flight attitudes, unless drainage is provided. Any drain valve installed must be accessible for drainage;
    (6) No vent may terminate at a point where the discharge of fuel from the vent outlet will constitute a fire hazard or from which fumes may enter personnel compartments; and
    (7) Vents must be arranged to prevent the loss of fuel, except fuel discharged because of thermal expansion, when the airplane is parked in any direction on a ramp having a one-percent slope.
    This goes all the way back to CAR4:
    Car4.jpg This is one of those regulations that was written in blood. My blood was almost added to it twice.
    I recognize that there are many BHs flying and pretty much all of them do not comply with this regulation nor is it required that they do but it is a design flaw that should be recognized even if you don't plan to change it. It needs to be recognized so that if you ever encounter its failure mode you'll know how to mitigate it.
    Leave a comment:
    replied
    I will post a pic of my choice when it is installed.
    Leave a comment:
  • Gerhard Rieger
    Hi, My header tank take 2,2 gal and have an 3/8' inlet (top) and outlet (bottom), and two 1/2' vents to each tank,I also fitted a drain at the low point of the tank to clear out any chance of water before flight. ( there should not be any water because the gascolator is fitted before the header tank .The IO 540 Lycoming do not require a return to the header tank, so, I do not have the hot fuel problem. I opted for the 1/2' vents to have the vent of double 1/2' to single 3/8 inlet. This will cause fuel to flow freely even if you un-ported a tank for a moment, it will refill that 3/8' fuel line in no time.
    replied
    Early on I noticed a lot of High wing airplanes had a header tank. The Bh system is obviously so well designed that I haven't heard of an issue, including feeding a 300hp engine on takeoff at very steep climb angles.
    With EFI, without a header tank, the system would be required to flow 35-45 gph, or whatever the pumps are pumping, 100% of the time. The tanks also have to vent that much air. It just kind of makes me tilt my head a little.
    With a header tank, the gravity feed only has to feed engine demand. Return fuel goes easily and quickly to and from a header tank. It makes me feel a bit better. Even if the header tank is less than a gallon in size. A gallon is a bit over 2 minutes of fuel at takeoff power, and 4 minutes at cruise.
    I will probably start with what is easy, and easy to pass DAR inspection. That is probably a small tank, and the two pumps from SDS.
    Leave a comment:
  • Chris In Milwaukee
    replied
    I’d considered something like this I the past:
    Free Shipping - RCI Aluminum Racing Fuel Cells with qualifying orders of $99. Shop Fuel Cells at Summit Racing.
    may have to add another connector or two depending on ventilation and return lines.
    Leave a comment:
    replied
    I have been trying to figure out how I wanted to do a header tank. One of my assumptions was wrong. Reading some of the documentation for EFII's system, they recommended a header tank of at least 3 gallons, because of fuel heating, if I remember right. I assumed SDS, the system I bought, was the same. Bad assumption.
    EFII uses a classic fuel rail EFI delivery. There is a common fuel rail on each cylinder bank, and fuel is returned from a pressure regulator on the end of that rail, AFTER the injectors. The fuel is heated, and that heat returns to the tank, or header tank. SDS uses a fuel divider, similar to the Bendix style I think. The FP regulator is mounted to this divider. Little heat is absorbed by the fuel so a large header tank is not required, according to the owner of SDS.
    So a bit of searching for "small header tank" yielded a few results, and also I found the term "surge tank" and "swirl pot". They are very common in racing applications, and converting an old car from a carburetor to EFI, kind of like I am doing. They come in lots of shapes and sizes, 1/2 gallons to 1.5 gallons. Some are just a tank, some with 1 or more internal pumps. A few even have a pressure regulator built in, and the "return fuel" never leaves the tank.
    If I can't find one I like I will just make my own. I like the idea of internal pumps to keep it all compact, and most leaks will be internal to the tank. Although keeping the tank itself from leaking (pump mount uses O rings) might be just as hard. If I rolled my own I could probably even put both the primary and secondary fuel filters in the tank. The only external fittings would be 1 or 2 outputs, 1 input form the main tanks, 1 return, and one vent. I could put the whole thing in a very thin CF (1 layer of 5 oz) sump with a drain line to the bottom of the aircraft.
    Leave a comment:
