Im getting to the point of ordering the flying wires. Ive read that a place ( unsure where) will make a deal if a group of us buy at once? Does anyone have that info and is anyone wanting to buy soon?
Flying wires group purchase?
I would be interested in a group purchase for a discount. Thanks!Originally posted by muleyman78 View PostIm getting to the point of ordering the flying wires. Ive read that a place ( unsure where) will make a deal if a group of us buy at once? Does anyone have that info and is anyone wanting to buy soon?Rob Caldwell
Was about $800 or so when I inquired, so might have even gone up a bit?
I ended up going the ACS swaged cable rout for about $200 total.
Do you have any pictures of that set up? If this is an effective method with an appealing look, I would like to consider it.Originally posted by Archer39J View Post...I ended up going the ACS swaged cable rout for about $200 total.
The Steen Tail Wires ends have right threads on one end, and Left threads on the other end. If both ends of each of the swaged cable were fabricated that way, then the cable could be rotated in place to adjust the tension to a precise degree without inducing a twisting force on the cable. I bet Spruce could fabricate them that way.
As an additional note, Steen sells stainless fork ends for our tail wire set up. They are expensive. The standard AN series of forks are not stainless, rather steel. I would be very proud to have the Steen fork ends on my tail. At the same time, (info I got from Waco Aircraft) stainless does not meet the AN specification for strength. I am sure Steen's fork ends are great products and plenty strong for our application, but dont think you have to go with their ends. The AN fork ends from Spruce were a significant savings. Use E-Z Turn to prevent galling though when installing the AN fork ends on the Steen stainless wires if you go that route.Brooks Cone
Hi, you will find that 420 stainless does meet the strength specs for AN665 clevis, once it is heat treated and tempered. We have been making flying wires, tie rods and fittings for over 12 years and have no problems. we can give a signfiicant discount for orders of 4 or more. Russ Ward www.vintageaero.com OldSchoolAero.com
You can shorten the run before you fully tighten the tabs at the hinge attach points as well, I think they cover this in the manual. I went this route so I didn't have to buy additional clevises. As you tighten the bolts at the hinge everything tightens up nicely. It also looks like the swaged clevis is more streamlined than the separate part and jam nut also.
Russ Ward here. We have been making streamline flying wires and tie rods for over 12 years and recently (last week) completed 3 sets of wires for 4place Bearhawks down here in New Zealand. On the lower round tie rods we recommend a layer of shrink wrap tubing to protect them. As a favour to the BearHawk community, we can now offer these wires at US$175 each for a single set or US$155 each for an order of 4 sets, with a lead time of 3 weeks. . We have polished Stainless Steel Clevis assemblies at US$40 each, or refurbished nickel plated steel assemblies at US$25 each. RussWard@hotmail.com or www.vintageaero.com.
