I got a hold of a Hi-Lo PAR36 LED landing light and really liked the function. The only housings I could find were heavy rubber ordeals and I thought I could do better. Designing the attach bracket it seemed I would still need to angle the lights separately for taxi and landing, or somehow cram two lights into each wingtip, neither things I really want to do. So I figured I could, for the weight penalty of a hinge and actuator, make the landing light adjustable. I can tie the movement to the Hi-Lo function so in the landing configuration the lights are pointed forward and when flipped to Lo for taxi they can be angled down. Need to figure out exactly what angles are needed so any input there would be helpful.
I took some photos and modeled this up, recreated the wing end and wingtip. I'm trying to push the light as far forward as I can for the best angle but I'm unsure of where exactly the wingtip will lay. Having to push it further aft wouldn't be the worst thing and easy to change. Looking at about 1.1 pounds each light right now but that's missing some nuts and bolts. Thinking a 3-position switch with off in the middle, this will keep the motor from being worked unnecessarily.
This is of course added complexity and cost, something else that can break. Easy to fix or lock out and is little additional weight though. Just an idea until I mock it up, still working the basic design.
