I had an EarthX fail. It was because of heat. I installed it engine side on the firewall with just the open aluminum box they sell. So, there wasn't much thermal protection. I also had the BMS warning light wired up. I saw the light turn on, turned off the master switch and made a beeline for the airport.
The EarthX swelled up (bulging out of the case) and leaked out the bottom. No smoke that I was aware of. The stuff that leaked burned right through the high temp Mark II paint on the tunnel. Oddly enough, the battery kept putting out normal voltage. Only damage was to the battery itself and the paint.
I called EarthX and talked to them about it. They were very friendly and full of good advice and said the battery needs to stay under 140 degrees F. We agreed that the warranty didn't cover it since it was likely getting too hot due to my installation location. They gave me a great discount on a new one.
Knowing this is a somewhat common problem, they have since come out with a thermal battery box. https://earthxbatteries.com/shop/the...0-900-vnt-1200 It's mainly for making sure the battery isn't cooked after shutdown or during a hot climb.
During my build I was afraid of the Lithium batteries and didn't want them in the cockpit with me. That decision and lack of thermal protection caused my failure. I think these are wonderful batteries and the failure mode is benign. Just make sure they don't get too hot!
