I originally mounted my xpdr and ADSB antennas down the belly along the stringers. After realizing I had almost no ground plane in that configuration, I did some research. I learned that shorter coax runs are better, and forward of comm antennas is better than aft. A few references were made to the placement of xpdr and ADSB mounted on the bottom of the cowl, as shown here. ADSB will go on the other side. Any thoughts? (Com antenna will at the back of the tunnel with the whip pointing rearward.)
