Does anyone know the preferred size of reamer to use with the AN174 close tolerance bolt?
Reamer size for AN174
Use a micrometer that you have just checked on a gage block. Order a reamer .0005" oversize. McMaster has them in 1/2 thousands increments. https://www.mcmaster.com/reamers If it is a real long bushing that is welded sometimes you have to go a bit larger as the bushing may not be a perfectly straight hole and your bolt may not go in. This was the case for my engine mounting bushings. A reamer will make the hole round but not perfectly straight if the bushing is longer than the reamer.
