Dynon CHT/EGT Brown Leads
  • Dynon CHT/EGT Brown Leads
    Does anyone know if it is permissible to cut the brown lead wires at different lengths to clean up installation? I know some of the older J and K type leads for other sensing products had to be kept at the same length. Have an inquiry to Dynon but no reply yet.
    Thanks
    Steve
    P203
    I cut them, and all is well. On second thought, perhaps this is the explanation for all that is wrong in my life.
      I cut mine as well on a different aircraft. No problems so far. From the install manual
      Wire length of CHT/EGT harnesses supplied by Dynon Avionics is not critical. It is acceptable to cut the thermocouple (brown) wire of the CHT/EGT harness to shorten the appropriate length for your installation. It is recommended to not cut the “armored” portion of the cable near the sensor end of the CHT or EGT sensors.
      page 7-44 in my manual
      Scott Ahrens
      Bearhawk Patrol Plans Built
      #254
        Thanks so much. My manual only has 6 pages in chapter 7. Thats why it’s titled “For Dummies” on the front cover. You obviously have the more in depth version.
        Continue wiring.
        thanks again
          Cut and connected all sensors. All 10 temp sensors are reading within 3 degrees of each other. All is well.
            Cutting them is fine.
