cooling air plenum
  • cooling air plenum
    Has anyone used the Vetterman Carbon Fiber cooling air plenum on their 0360 Patrol? It looks interesting but I would be here about some real world experience.
    I saw that Clint B had made one for his plane, but is he going into production?
      Mark G brought this up a while ago here on this forum. https://bearhawkforums.com/forum/pro...plenum-for-360
      It was in research and development phase when I contacted Clint about it. He hopes to offer a complete kit, but He was offering cylinder wrap arounds for a price and was breaking in his engine with it. Seems an elegant and simple solution to me.
        Hi Dennis! Are you seeing high CHT's? It's been really warm down here (like 94 OAT!). My CHT's are rarely over 365 in cruise. I'd still like to have more control over Oil temp, but even at the highest OAT's, I'm about 220 OT. I've got the Vans baffle kit, under the standard cowl configuration. I'd have guessed that you guys were enjoying cooler weather and corresponding lower temps.
          Hi Bill, what MP , RPM and Fuel flow are you running in cruise to see CHT's around 365? We have seen oil temps as high as 220 on a hot day also. Running 23in and 2350 RPM we need to burn 10.5 GPH to keep CHT's in the 375 range. On a cooler day we can get FF down to 9.7. We also have the Vans baffle kit.
          • Bdflies
            Bdflies commented
            Tell ya what I'll do; I’ll do a flight at those exact settings and get back to you. That way, we’ll be apples to apples. I recall that y’all had CHT issues, early on, but figured that was past.
            I’ll get back ASAP with a screenshot!
          A bit off point but one thing so can tell you on oil temps, is that after an extensive independent study🤔, the oil temperature on my Patrol is 25f cooler when I run Aeroshell W100plus vs Phillips XC20/50. Changed the oil 3 times during a heatwave to prove it.
          • Bdflies
            Bdflies commented
            Mike, am I understanding that Aeroshell 100+ straight mineral 50 wt oil will run cooler?
            Man, if that’s the case, I need a couple of cases!
          Hi Bill, yes but not the aeroshell 100 mineral break in oil. The W100 or W100plus.
            82B4A990-37A3-4EDC-827F-1AEB77DD956B.jpegFull rich.
            Finally got a chance to fly. Cloud cover kept OAT down a bit. See pics
              Bill, Based on what you are seeing we are seeing similar results. At full rich (your top screen shot) we would be in the 11 to 12 GPH range. D&D
