When thinking about electric ignition, the most complex part is keeping it powered. This leads most people down the P-mag road, but there is no way I'd buy anything that had prior issues, followed by a multi year delay, that requires 100 hour inspection.
This only leaves 3 options:
1. Using one mag and one EI. I haven't decided if I like this idea.
2. Using Surefly or SDS CPI-1 (or something else) and making sure that you have redundant power (with at least one of them pathed to a secondary battery that can be isolated).
3. Using the SDS CPI-2 and connecting a small led acid battery to be dedicated to this task.
A lot of people think they have redundant power, but their system can't survive a large short to ground, contactor failure, or connector failure. From a wiring standpoint using a CPI2 is probably easier because it isolates the backup battery from the rest of the system by default. I'd go that way if I had room on my panel for the head and a secondary alternator for the pump pad.
From a plug perspective, I have no issue with NGK plugs, they are great! It's the adapters I'm not so hot on....
