Gear Mount Bolts - Lube - Bushings
  • Gear Mount Bolts - Lube - Bushings
    I'm starting LSA gear fab and had a question for guys with higher time Bearhawks.
    How are you handling lubrication of the gear mount bolts and have you noticed any play/wear developing in the gear leg bore or bolts?
    ISA140, 275 hrs and two many landings to count as my 15 year old grandson is learning, NO problems. Stinger
      I replace all my gear bolts at annual. Cheap compared to the alternative. Especially on the tail. The leaf spring to fuselage bolt has been bent on both annuals. And I found the rear right gear leg to fuselage bolt bent last year. MF to get them out. New ones go in perfect.
        I haven't found those bolts bend. Others yes, not those two locations
      Glad to hear the LSA is doing well and you are able to pass down flying to your grandson in an airplane built with your hands. That is very cool.
      That rear gear attach point sees some very high loads on a hard hit with the Bearhawk gear/shock strut geometry.
