Drain Holes
  • Drain Holes
    I am almost done with covering the empennage and need to add drain holes before I seal all of it with Ekobond. Of course, the answer is to put them where water would collect, but I was wondering if anyone had photos of where they put theirs. I'm planning small round doilies to reinforce the holes per the manual. Thoughts and photos appreciated!
    For the surfaces only two holes . They also act as vents allowing evaporation. Then nothing is trapped.
      FWIW, this is how I made the doilies: http://www.mykitlog.com/users/displa...=292877&row=37
      Are you talking about the end of the fuselage where the tail wheel mounts?
      • Mark Dickens
        Mark Dickens commented
        No, just the tail feathers for now. I figure I'll just melt a hole back there when I get to that. I was more curious as to where everyone put their holes, but I think I have it sorted now
      A soldering iron makes a neat hole.
      • Mark Dickens
        Yep, that's what I'll use!
      • jaredyates
        jaredyates commented
        The polyfiber video shows following the soldering iron with a sharpened pencil while the hole is still hot. It makes it even neater.
      • Mark Dickens
        Jared, I saw an earlier post where you point out that putting the holes in the trailing edge through the fabric overlap and tapes also meets the requirement for reinforcement. That's precisely what I'm going to do, along with the pencil trick.
