What is everyone using for their tubing from pitot tube to instruments? I'd like to run the tubing before I close up the skin on the bottom of the nose ribs. I see safeair makes a kit sold through Avery, but it looks like the same tubing and connectors you can go buy at Home Depot?
Pitot tubing
I used the Home Depot type.
It was cheap, like the Budgie, but a little on the bulky and heavy side.
If I were doing it again, I would use the cheapest Nylaflow hose like you can use for brake lines, alone with brass hose fittings - avoid the plastic Nylaflow fittings like the plague IMHO.
2c
I have used Tygon tubing. Ref :http://aircraftproducts.wicksaircraf...ilter=&by=prod.
I don't know how to assign a URL to "this" :-)
Wes
