Has anyone experimented with changing the aileron bell crank angle as a means of further reducing adverse yaw ? I was thinking it would relatively straight forward to make a second set and try out. Any other ideas that people have experimented with ?
Offset aileron bellcranks
Builders Log - We build planesTags: None
I'm not sure that could be accomplished through the bell cranks. One thing to remember, Bob told me this while talking with him a couple weeks ago, is that an airplane without a certain amount of adverse yaw does not slip very well. The less adverse yaw, the more control deflection and control force will be needed to get an effective slip.
One issue with increasing aileron differential is that crosswind handling may suffer if there's reduced drag from the downwind aileron. More important on a tailwheel aircraft than a nose wheel aircraft.
I haven't really used sideslipping in anger other than to try it. The flaps are pretty sizable and draggy and at lighter weights it's relatively easy to increase the descent rate just by lowering the nose. At heavier weights it may be more useful if needing to increase the descent rate.Last edited by Nev; 09-24-2023, 02:08 AM.Nev Bailey
Offsetting bell cranks and/or the control horn can both be used to increase differential. Bob used 90 deg bell cranks, so he must have done it with the control horn offset. It might have clearance issues trying to get more up aileron. The pushrod might hit the "alien" hinge bracket.
I have considered doing this for a while. I’m pretty sure it wouldn’t be to hard to do. I just need to look at a Cessna or Piper bell crank to see what ratio of offset they use. I wouldn’t worry about slipping with offset bell cranks, the rudder is more than big enough to handle it.
Originally posted by bearhawk2015 View PostI have considered doing this for a while. I’m pretty sure it wouldn’t be to hard to do. I just need to look at a Cessna or Piper bell crank to see what ratio of offset they use. I wouldn’t worry about slipping with offset bell cranks, the rudder is more than big enough to handle it.Nev Bailey
Originally posted by rodsmith View PostKevin D. (AZBearhawk272) has rigged Bearhawks with the aileron cross cable adjusted shorter to reduce adverse yaw. There is a thread titled "aileron rigging" started 1-31-2018 with good information.
Actually I just found Kev's reply here.Last edited by Nev; 09-25-2023, 02:29 PM.Nev Bailey
